Help
Lite-On LightScribe SHM-165H6S Chassis Replacement
Action Shots
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Bullets!
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Member-Contributed Guide
Removing the top and bottom covers of the drive.
  • Author: James Biggs
  • Time estimate: 5 minutes
  • Difficulty: Very easy
Remove the top cover of the optical drive to access the internals and replace any malfunctioning components.
Step 1 Chassis  ¶
Insert an open paper clip into the small hole on the left side of the faceplate. After the tray opens, extend it fully.
Step 1 Chassis  ¶
  • Insert an open paper clip into the small hole on the left side of the faceplate.
  • After the tray opens, extend it fully.
Step 2  ¶
Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate. Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate. Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate.
Step 2  ¶
  • Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate.
Step 3  ¶
Pull the faceplate away from the main chassis.
Step 3  ¶
  • Pull the faceplate away from the main chassis.
Step 4  ¶
Unscrew the four 8.5 mm screws on the bottom chassis using a Philips #2 screwdriver.
Step 4  ¶
  • Unscrew the four 8.5 mm screws on the bottom chassis using a Philips #2 screwdriver.
Step 5  ¶
Lift the top and bottom chassis straight up in order to remove them. Lift the top and bottom chassis straight up in order to remove them.
Step 5  ¶
  • Lift the top and bottom chassis straight up in order to remove them.
