Help
Dell Dimension 4600 Fan Replacement
Needs Better Images
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Markup Mishap
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
This is a guide on how to replace the cooling fan located inside a Dell Dimension 4600.
  • Author: Tim
  • Time estimate: 5 minutes
  • Difficulty: Easy
Use this guide to replace the fan inside of your Dell Dimension 4600.
Sections
Step 1 Fan  ¶
Lay the computer flat on it's side so that you are looking down at all of the components.
Step 1 Fan  ¶
  • Lay the computer flat on it's side so that you are looking down at all of the components.
  • Locate the fan and its black, red, and white power cable.
Step 2  ¶
Follow the power cable to the motherboard connection and remove it by pressing down on the clip.
Step 2  ¶
  • Follow the power cable to the motherboard connection and remove it by pressing down on the clip.
Step 3  ¶
Locate the release clip on the side of the fan and hold it down with your thumb.
Step 3  ¶
  • Locate the release clip on the side of the fan and hold it down with your thumb.
Step 4  ¶
While holding the release clip down, look on the outside of the case where the fan lies.
Step 4  ¶
  • While holding the release clip down, look on the outside of the case where the fan lies.
  • Using the four black notches as a reference, slide the fan towards the open side releasing the fan.
