Help
iBook G4 12" 1.33 GHz Top Shield Replacement
The metallic top shield protects the logic board from electromagnetic interference.
Step 1 Top Shield  ¶
Remove the fifteen 3 mm Phillips screws securing the top shield to the computer.
Step 1 Top Shield  ¶
  • Remove the fifteen 3 mm Phillips screws securing the top shield to the computer.
  • Remove the following 16 screws:
  • Thirteen 3 mm Phillips.
  • One 3 mm Phillips. (actual screw not present in image)
  • Two 4 mm Phillips.
  • Be sure to fit the screw near the left hinge through the loop in the display data cable, securing the cable to the upper case.
Step 2  ¶
Lift the top shield up from the right side, minding the upper left corner, which may catch on the metal framework.
Step 2  ¶
  • Lift the top shield up from the right side, minding the upper left corner, which may catch on the metal framework.
