Help
Blackberry Curve 8320 Speaker Replacement
Bullets!
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
This repair guide shows the removal and replacement of the phone's main speaker.
This guide will show you how to:
  • Remove the battery
  • Remove the front panel
  • Replace the speaker
Step 1 Speaker  ¶
Use a T6 Torx screwdriver to remove the four screws located on the corners of the keyboard frame. The screws are 6mm long. The screws are 6mm long.
Step 1 Speaker  ¶
  • Use a T6 Torx screwdriver to remove the four screws located on the corners of the keyboard frame.
  • The screws are 6mm long.
Step 2  ¶
After the bottom two screws have been removed the side casings can be removed. After the bottom two screws have been removed the side casings can be removed.
Step 2  ¶
  • After the bottom two screws have been removed the side casings can be removed.
Step 3  ¶
Remove the back case. The speaker is located on the back case. The speaker is located on the back case.
Step 3  ¶
  • Remove the back case.
  • The speaker is located on the back case.
