Help
MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Lower Case Replacement
Replacing the metal bottom case.
Step 1 Lower Case  ¶
Image 1/2: Peel up the iSight cable from the black tape at the top of the left fan.
Step 1 Lower Case  ¶
  • Lift the heat sink out of the computer.
  • Peel up the iSight cable from the black tape at the top of the left fan.
  • Peel up the left ambient light sensor cable from above the left fan, removing tape as necessary.
  • Remove the left fan from the computer.
  • If you need to mount the heat sink back into the laptop, we have a thermal paste guide that makes replacing the thermal compound easy.
Step 2  ¶
Image 1/1: Apple was kind enough to include a label showing where each color antenna cable plugs in - just make sure to look at this when reconnecting the antenna cables.
Step 2  ¶
  • Disconnect the two antenna cables attached to the Airport Extreme card.
  • Apple was kind enough to include a label showing where each color antenna cable plugs in - just make sure to look at this when reconnecting the antenna cables.
  • If you have a MacBook Pro 15" Core 2 Duo A1226, there are three antenna cables on the Airport card.
Step 3  ¶
Image 1/1:
Step 3  ¶
  • Deroute the Airport antenna cables from their channel in the left speaker.
Step 4  ¶
Image 1/1:
Step 4  ¶
  • Remove the single black T6 Torx screw located just above the Airport Extreme card.
Step 5  ¶
Image 1/1: Lift the Airport Extreme card up and slide it out of its connector.
Step 5  ¶
  • Lift the small silver metal retaining bracket up and out of the computer.
  • Lift the Airport Extreme card up and slide it out of its connector.
Step 6  ¶
Image 1/1:
Step 6  ¶
  • Peel up the orange hard drive cable from above the ExpressCard cage.
Step 7  ¶
Image 1/1:
Step 7  ¶
  • Disconnect the speaker cable from the corner of the left I/O board.
Step 8  ¶
Image 1/2: Continue to free the speaker cable from the black tape until it is free from all three sections of tape.
Step 8  ¶
  • Carefully peel up the black adhesive tape securing the speaker cable along the rear edge of the lower case.
  • Continue to free the speaker cable from the black tape until it is free from all three sections of tape.
Step 9  ¶
Image 1/2: Use a spudger to pry up the right speaker from the lower case.
Step 9  ¶
  • Remove the single black T6 Torx screw securing the right speaker to the lower case.
  • Use a spudger to pry up the right speaker from the lower case.
  • Remove the speakers from the computer.
Step 10  ¶
Image 1/1:
Step 10  ¶
  • Use a spudger to disconnect the inverter cable from the corner of the left I/O board.
Step 11  ¶
Image 1/2: Two 9.5 mm silver T6 Torx screws with threads on only part of the shaft on the inside of the display hinges.
Step 11  ¶
  • Support the display with one hand while removing the following 3 screws:
    • Two 9.5 mm silver T6 Torx screws with threads on only part of the shaft on the inside of the display hinges.
    • One 9.5 mm silver T6 Torx screw with threads on the entire shaft on the outside of the left hinge.
  • Grasp the display assembly on both sides and lift it up and out of the computer.
Step 12  ¶
Image 1/1:
Step 12  ¶
  • Disconnect the IR and sleep light cables from their connectors above the hard drive, removing tape as necessary.
Step 13  ¶
Image 1/1:
Step 13  ¶
  • Remove the two silver T6 Torx screws securing the hard drive retaining bracket to the lower case.
Step 14  ¶
Image 1/1: Lift the hard drive up from the right side and remove it and the attached cable from the computer.
Step 14  ¶
  • Lift the hard drive retaining bracket up and out of the computer.
  • Lift the hard drive up from the right side and remove it and the attached cable from the computer.
Step 15  ¶
Image 1/2: Four black T6 Torx screws securing the left I/O board to the lower case.
Step 15  ¶
  • Remove the following 7 screws/standoffs:
    • Four black T6 Torx screws securing the left I/O board to the lower case.
    • Two silver T6 Torx screws securing the battery connector to the lower case.
    • One 4 mm standoff located between the audio jacks.
  • Lift the left I/O board up from the right side and slide it out of the computer.
Step 16  ¶
Image 1/3: Use a spudger to pry the right thermal sensor off the lower case. Repeat the same procedure for the left thermal sensor.
Step 16  ¶
  • Peel up the orange Kapton tape covering the right thermal sensor. Repeat the same procedure for the left thermal sensor.
  • Use a spudger to pry the right thermal sensor off the lower case. Repeat the same procedure for the left thermal sensor.
  • Use a spudger to pry up the PRAM battery off the lower case.
  • Lower case remains.
