Help
HTC Maple 100 Motherboard Replacement
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Confusing Text
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
After removing the battery and the backpanel
Be cautious about the ribbon cable
Sections
Step 1 Motherboard  ¶
Remove the one 3.3mm #00 screw. Remove the one 3.3mm #00 screw.
  • Remove the one 3.3mm #00 screw.
Step 2  ¶
Use your finger or the plastic opening tool to unclip the board. Be aware of the ribbon cable connected to the motherboard inside the phone.
Step 2  ¶
  • Use your finger or the plastic opening tool to unclip the board.
  • Be aware of the ribbon cable connected to the motherboard inside the phone.
Step 3  ¶
Peel off the yellow piece of tape from the phone Peel off the yellow piece of tape from the phone
Step 3  ¶
  • Peel off the yellow piece of tape from the phone
Step 4  ¶
First flip up the retaining flap with your fingernail or a plastic opening tool. Pull on the ribbon cable gently with your fingers Pull on the ribbon cable gently with your fingers
Step 4  ¶
  • First flip up the retaining flap with your fingernail or a plastic opening tool.
  • Pull on the ribbon cable gently with your fingers
Step 5  ¶
Split apart the motherboard and front panel. Remove the other yellow piece of tape off of the end of the ribbon cable. Split apart the motherboard and front panel. Remove the other yellow piece of tape off of the end of the ribbon cable.
Step 5  ¶
  • Split apart the motherboard and front panel. Remove the other yellow piece of tape off of the end of the ribbon cable.
Step 6  ¶
Gently pull on the ribbon cable to separate the motherboard. Gently pull on the ribbon cable to separate the motherboard.
Step 6  ¶
  • Gently pull on the ribbon cable to separate the motherboard.
