Help
MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Right Thermal Sensor Replacement
This detects the internal temperature of your machine for heat management.
Step 1 Right Thermal Sensor  ¶
Image 1/2: Disconnect the right thermal sensor cable from the logic board by placing a spudger beneath the cable and lifting up.
  • Use caution when removing the thermal sensor connector. The connector can easily break off the logic board if this step is performed improperly.
  • Disconnect the right thermal sensor cable from the logic board by placing a spudger beneath the cable and lifting up.
  • Peel up the orange Kapton tape covering the right thermal sensor.
  • Use a spudger to pry the right thermal sensor off the lower case.
