Help
Technique: Opening Procedure
Prerequisite Only
Prerequisite Only
Please note that this guide is only a prerequisite for other guides.
Opening procedure for an iPhone 7 Plus.
  • Author: Evan Noronha
  • Time estimate: 15 - 45 minutes
  • Difficulty: Moderate
Prerequisite only guide to open an iPhone 7 Plus, allowing access to internal components for repair or replacement.
Step 1 Opening Procedure  ¶
Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
  • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
  • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
Step 2  ¶
Apply a suction cup to the lower half  of the front panel, just above the home button. Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
Step 2  ¶
  • Apply a suction cup to the lower half of the front panel, just above the home button.
  • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
Step 3  ¶
Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case. Insert the flat end of a spudger into the gap. The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, rock the screen up and down to weaken the adhesive until you can fit a spudger inside.
Step 3  ¶
  • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
  • Insert the flat end of a spudger into the gap.
  • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, rock the screen up and down to weaken the adhesive until you can fit a spudger inside.
  • While pulling up on the suction cup, twist the spudger to widen the opening between the screen and rear case.
Step 4  ¶
Insert the flat end of the spudger between the front panel and the rear case at the lower left edge of the iPhone. Slide the spudger up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place. Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
Step 4  ¶
  • Insert the flat end of the spudger between the front panel and the rear case at the lower left edge of the iPhone.
  • Slide the spudger up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
  • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
Step 5  ¶
Remove the spudger from the left side of the phone and insert the flat end into the bottom right corner. Slide the spudger up the right edge of the phone to the top corner, breaking up the adhesive holding the display in place.
Step 5  ¶
  • Remove the spudger from the left side of the phone and insert the flat end into the bottom right corner.
  • Slide the spudger up the right edge of the phone to the top corner, breaking up the adhesive holding the display in place.
Step 6  ¶
Pull up on the suction cup to lift up the display and open the iPhone. Do not raise the display more than 10º as there are delicate ribbon cables along the right edge of the device connecting the display to the logic board.
Step 6  ¶
  • Pull up on the suction cup to lift up the display and open the iPhone.
  • Do not raise the display more than 10º as there are delicate ribbon cables along the right edge of the device connecting the display to the logic board.
Step 7  ¶
Pull up on the small nub on the suction cup to remove it from the front panel. Pull up on the small nub on the suction cup to remove it from the front panel.
Step 7  ¶
  • Pull up on the small nub on the suction cup to remove it from the front panel.
Step 8  ¶
Slide an opening pick underneath the display along the top edge of the phone to loosen the last of the adhesive. Slide an opening pick underneath the display along the top edge of the phone to loosen the last of the adhesive.
Step 8  ¶
  • Slide an opening pick underneath the display along the top edge of the phone to loosen the last of the adhesive.
Step 9  ¶
Pull the display assembly slightly away from the top edge of the phone to disengage the clips holding it to the rear case. Open the iPhone by swinging the display up from the left side, like the back cover of a book. Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
Step 9  ¶
  • Pull the display assembly slightly away from the top edge of the phone to disengage the clips holding it to the rear case.
  • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
  • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
