Help
MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Hard Drive Replacement
You can install hard drives up to 9.5mm thick.
Step 1 Hard Drive  ¶
Image 1/1: Remove the two silver T6 6 mm Torx screws from the left side of the hard drive.
Step 1 Hard Drive  ¶
  • Remove the two silver T6 6 mm Torx screws from the left side of the hard drive.
  • You'll need to transfer these screws to your new hard drive if you're changing drives.
Step 2  ¶
Image 1/1: Remove the two black T6 Torx screws and white rubber bumpers from the right side of the hard drive.
Step 2  ¶
  • Remove the two black T6 Torx screws and white rubber bumpers from the right side of the hard drive.
  • You'll need to transfer these screws and bumpers to your new hard drive if you're changing drives.
  • If you are installing a new hard drive, we have an OS X install guide to get you up and running.
