Help
MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Optical Drive Replacement
Upgrade or replace the SuperDrive (requires a slim drive) in your MacBook Pro 15" Core 2 Duo Models A1226 and A1260.
Upgrade or replace the SuperDrive (requires a slim drive).
Step 1 Optical Drive  ¶
Image 1/2: Remove the two silver Phillips screws securing the mounting bracket to the left side of the optical drive.
  • If your new optical drive already has brackets on it, you'll only need to transfer the data cable to your new drive. Skip the bracket removal steps below.
  • Remove the two silver Phillips screws securing the mounting bracket to the left side of the optical drive.
  • Rotate the drive and disconnect the orange ribbon cable from the optical drive.
Step 2  ¶
Image 1/1:
Step 2  ¶
  • Remove the two Phillips screws securing the mounting bracket to the rear of the optical drive.
Step 3  ¶
Image 1/1: If you have a CD or any other object jammed in your optical drive, we have an [guide|772|optical drive repair guide].
Step 3  ¶
  • Rotate the drive and remove the two Phillips screws securing the mounting bracket to the right side of the optical drive.
  • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
