Help
Removing Bottom of iMac G4 15" 700 MHz EMC 1873
Removing the white bottom of the the base, giving us access to the components inside.
  • Author: Elliot Freerks
  • Time estimate: 10 - 20 minutes
  • Difficulty: Easy
We will unscrew the bottom faceplate, then remove the base to access the internal components.
Step 1 Removing the Lower Case  ¶
Remove the four  28.07mm Torx #15 screws from the lower case.
  • Remove the four 28.07mm Torx #15 screws from the lower case.
Step 2  ¶
Open the base by carefully pulling straight off, do not rotate the cover. Open slowly to ensure that no cables are damaged or disconnected.
Step 2  ¶
  • Open the base by carefully pulling straight off, do not rotate the cover.
  • Open slowly to ensure that no cables are damaged or disconnected.
Step 3  ¶
Squeeze the small black tab and wiggle gently to remove the colored power cable.
Step 3  ¶
  • Squeeze the small black tab and wiggle gently to remove the colored power cable.
  • Do not pull directly on the colored wires.
  • Do not remove black grounding wire.
Step 4  ¶
Grab both sides of the blue connector and firmly pull to remove it from the mother board.
Step 4  ¶
  • Grab both sides of the blue connector and firmly pull to remove it from the mother board.
  • Do not pull directly on the ribbon cable.
