Help
MacBook Air 11" Mid 2011 Lower Case Replacement
Replace the lower case on your MacBook Air 11" Mid 2011.
Use this guide to remove the lower case.
Step 1 Lower Case  ¶
Shut down and close your computer. Lay it on a soft surface top-side down.
Step 1 Lower Case  ¶
  • Shut down and close your computer. Lay it on a soft surface top-side down.
  • Remove the following ten screws:
  • Two 8 mm 5-point Pentalobe screws
  • Eight 2.5 mm 5-point Pentalobe screws
  • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
Step 2  ¶
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Step 2  ¶
  • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
