Help
Alcatel OneTouch Pop Icon Headphone Jack Replacement
This guide will demonstrate the removal of the headphone jack on a Alcatel Onetouch POP Icon.
  • Author: John Halsey
  • Time estimate: 30 - 45 minutes
  • Difficulty: Difficult
Removing the headphone jack requires that you remove the solder attaching the headphone jack to the motherboard. This is not a process that should be tried unless you have some experience soldering.
Also, make sure, that when using the metal spudger that may cause electrostatic discharge, to ground yourself by touching a metal object before using the spudger.
Step 1 Headphone Jack  ¶
Soldering produces fumes that can be dangerous. Only solder in a well ventilated area. Follow the directions in this attached guide for tips on soldering: How To Solder and Desolder Connections.
  • Soldering produces fumes that can be dangerous. Only solder in a well ventilated area.
  • Follow the directions in this attached guide for tips on soldering: How To Solder and Desolder Connections.
