Help
Acer Iconia Tab A200 Speaker Replacement
This guide will show you how to replace the dual interior speakers for the Acer Iconia Tab A200.
  • Author: Steve Chiu
  • Time estimate: 15 minutes
  • Difficulty: Easy
The dual speakers are used to play sound from the device. The wiring for the speakers may also be difficult to see as they are black and blends in with the case. If you are having trouble see the wires try using a flashlight.
Step 1 Speaker  ¶
After removing the battery use a Phillips head #00 screwdriver to remove the 3.0 mm screws holding the dual speakers in place. After removing the battery use a Phillips head #00 screwdriver to remove the 3.0 mm screws holding the dual speakers in place.
Step 1 Speaker  ¶
  • After removing the battery use a Phillips head #00 screwdriver to remove the 3.0 mm screws holding the dual speakers in place.
Step 2  ¶
Once the screws are removed, lift up on the speakers to remove them from the case.
Step 2  ¶
  • Once the screws are removed, lift up on the speakers to remove them from the case.
Step 3  ¶
Once you have removed the speakers from the case, disconnect the speakers from the motherboard by pulling the cable out horizontally. Do not pull up on the cable.
Step 3  ¶
  • Once you have removed the speakers from the case, disconnect the speakers from the motherboard by pulling the cable out horizontally. Do not pull up on the cable.
