Help
Sony SRS-X55 I/O Board Replacement
Replace the I/O board on your Sony SRS-X55 speaker.
If your Sony SRS-X55 speaker won't play sound from the auxiliary jack, replacing the I/O board may resolve the problem.
Step 1 I/O Board  ¶
Remove  the two Phillips screws from the  I/O board. Remove the front panel to the speaker by pushing on the two tabs in the corners.
Step 1 I/O Board  ¶
  • Remove the two Phillips screws from the I/O board.
  • Remove the front panel to the speaker by pushing on the two tabs in the corners.
Step 2  ¶
Disconnect the ribbon cable from the  I/O board.
Step 2  ¶
  • Disconnect the ribbon cable from the I/O board.
  • Carefully remove the I/O board from the speaker.
