Help
AmazonBasics B0050BPWBQ On/Off Switch Replacement
If the On/Off switch no longer works, it may need to be replaced.
  • Author: Natalie Meert
  • Time estimate: 10 minutes
  • Difficulty: Easy
The On/Off switch located on the front panel may become damaged and no longer function correctly. With a dysfunctional switch, you may not be able to get the shredder to operate.
Step 1 On/Off Switch  ¶
Pull the front panel away from the shredding unit. Locate the black On/Off switch attached to the front panel where the control board was once attached. Squeeze the wings of the On/Off switch from the inside of the front panel to detach it from its slot in the panel.
  • Pull the front panel away from the shredding unit.
  • Locate the black On/Off switch attached to the front panel where the control board was once attached.
  • Squeeze the wings of the On/Off switch from the inside of the front panel to detach it from its slot in the panel.
