Help
MacBook Pro 15" Unibody Early 2011 Optical Drive Replacement
Prerequisite Only
Prerequisite Only
Please note that this guide is only a prerequisite for other guides.
Optical Drive replacement.
Step 1 Optical Drive  ¶
Disconnect the camera cable connector from its socket on the logic board.
  • Disconnect the camera cable connector from its socket on the logic board.
  • Do not lift up on the cable as you disconnect it from the logic board. Pull the cable parallel to the face of the logic board.
Step 2  ¶
Use the flat end of a spudger to pry the AirPort/Bluetooth connector up from its socket on the logic board.
Step 2  ¶
  • Use the flat end of a spudger to pry the AirPort/Bluetooth connector up from its socket on the logic board.
Step 3  ¶
Use the flat end of a spudger to pry the optical drive connector up from its socket on the logic board.
Step 3  ¶
  • Use the flat end of a spudger to pry the optical drive connector up from its socket on the logic board.
Step 4  ¶
Remove following two screws: Take care, as these screws are unusually easy to strip. Apply firm pressure while unscrewing. Read comments before proceeding.
Step 4  ¶
  • Remove following two screws:
  • Take care, as these screws are unusually easy to strip. Apply firm pressure while unscrewing. Read comments before proceeding.
  • One 8.6 mm Phillips screw
  • One 3.9 mm Phillips screw
  • Carefully rotate the AirPort/Bluetooth board housing (with AirPort/Antenna cables still attached) out of the lower case.
Step 5  ¶
Remove the three 3.5 mm T6 Torx screws securing the optical drive to the upper case.
Step 5  ¶
  • Remove the three 3.5 mm T6 Torx screws securing the optical drive to the upper case.
Step 6  ¶
Lift the optical drive near its connector and pull it away from the upper case to remove it from the computer.
Step 6  ¶
  • Lift the optical drive near its connector and pull it away from the upper case to remove it from the computer.
