Help
Nikon Coolpix P530 CCD Sensor Replacement
This is a step by step guide for replacing a broken CCD sensor in a Nikon Coolpix P530 camera.
  • Author: Alan Weihe
  • Time estimate: 8 minutes
  • Difficulty: Easy
The CCD sensor can be sensitive to scratches and other contaminants that would disrupt its surface yielding blurry images. This guide will provide the procedure necessary to replace this component.
Sections
Step 1 CCD Sensor  ¶
Disconnect the ribbon cable connector by prying upwards on the part using the plastic opening tools. Disconnect the ribbon cable connector by prying upwards on the part using the plastic opening tools. Disconnect the ribbon cable connector by prying upwards on the part using the plastic opening tools.
Step 1 CCD Sensor  ¶
  • Disconnect the ribbon cable connector by prying upwards on the part using the plastic opening tools.
Step 2  ¶
Remove the 3mm screws highlighted in red using the Philips #000 screwdriver. There should be a total of three screws removed in this step. There should be a total of three screws removed in this step.
Step 2  ¶
  • Remove the 3mm screws highlighted in red using the Philips #000 screwdriver.
  • There should be a total of three screws removed in this step.
Step 3  ¶
Use the tweezers to remove the CCD sensor carefully. Use the tweezers to remove the CCD sensor carefully. Use the tweezers to remove the CCD sensor carefully.
Step 3  ¶
  • Use the tweezers to remove the CCD sensor carefully.
