Help
Panasonic DVD-RV31 Player Disk Drive Replacement
Bullets!
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Action Shots
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Removing the disk drive for replacement, to clean the laser, or access the power board.
  • Author: William
  • Time estimate: 1 - 5 minutes
  • Difficulty: Difficult
Step 1 Disk Drive  ¶
Locate the 4 screws securing the disk drive assembly. There are two on each side. Use a narrow screwdriver to remove all 4 screws. Remove the blue ribbon wire from its connector. When doing this, be cautious to not damage the connector.
Step 1 Disk Drive  ¶
  • Locate the 4 screws securing the disk drive assembly. There are two on each side.
  • Use a narrow screwdriver to remove all 4 screws.
  • Remove the blue ribbon wire from its connector. When doing this, be cautious to not damage the connector.
Step 2  ¶
Lift assembly by the front to pull metal bracket from the power board.
Step 2  ¶
  • Lift assembly by the front to pull metal bracket from the power board.
  • Pull up back end and lift drive out.
Step 3  ¶
With the drive assembly separate from the player, hold as shown and pull the bracket edges away from the disk drive.
Step 3  ¶
  • With the drive assembly separate from the player, hold as shown and pull the bracket edges away from the disk drive.
  • Lift bracket off and reserve for re-assembly.
