Help
Bose Soundlink III Battery Replacement
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Replace the battery of your Bose Soundlink III.
If your SoundLink III exhibits significantly decreased battery life or no longer takes a charge, you may need a new battery. In this guide, you will learn how to open up your Bose Soundlink III and replace the battery.
Step 1 Battery  ¶
Use a spudger to pry the rubber pads off of the bottom panel of the SoundLink.
Step 1 Battery  ¶
  • Use a spudger to pry the rubber pads off of the bottom panel of the SoundLink.
  • The rubber pads should have enough adhesive to stick when you reassemble them at the end. If not, however, you may need your own adhesive.
Step 2  ¶
Remove the two 12.5 mm screws using a Phillips #2 screwdriver. These screws may be difficult to remove. If necessary, use a lever for extra torque.
Step 2  ¶
  • Remove the two 12.5 mm screws using a Phillips #2 screwdriver.
  • These screws may be difficult to remove. If necessary, use a lever for extra torque.
  • Remove the bottom panel.
Step 3  ¶
Flip the rear panel back to allow access to the SoundLink's battery.
Step 3  ¶
  • Flip the rear panel back to allow access to the SoundLink's battery.
Step 4  ¶
Remove the two 12.5 mm Phillips #2 screws from the sides of the battery. Remove the two 12.5 mm Phillips #2 screws from the sides of the battery.
Step 4  ¶
  • Remove the two 12.5 mm Phillips #2 screws from the sides of the battery.
