Help
Technique: Eton Soulra XL Woofer Wire Repair
Repair the connection to the woofer of the Eton Soulra XL.
  • Author: Nate Kilmer
  • Time estimate: 2 hours
  • Difficulty: Moderate
The Eton Soulra XL has two woofers that are relatively easy to access and reconnect, should one become disconnected. This guide will provide step-by-step instructions to disassemble, clean, and repair loose connections. You will need to know how to solder; review How To Solder and Desolder Connections if you are unfamiliar with the process.
Step 1 Eton Soulra XL Woofer Wire Repair  ¶
Gently pull down and out on the front cover; it should come off easily.
  • Gently pull down and out on the front cover; it should come off easily.
  • This step is not necessary; if the cover does not come off easily it can be left on.
Step 2  ¶
Remove two screws from each side using a H2.5 hexagonal screwdriver.
Step 2  ¶
  • Remove two screws from each side using a H2.5 hexagonal screwdriver.
Step 3  ¶
Pry off "Eton" logo from the side speaker covers using a pry tool.
Step 3  ¶
  • Pry off "Eton" logo from the side speaker covers using a pry tool.
  • Be careful not to break the emblem when removing.
Step 4  ¶
Remove the two screws that were covered by the "Eton" logo using a PH0 screwdriver.
Step 4  ¶
  • Remove the two screws that were covered by the "Eton" logo using a PH0 screwdriver.
Step 5  ¶
The side speaker covers should come off easily now; remove them.
Step 5  ¶
  • The side speaker covers should come off easily now; remove them.
Step 6  ¶
Remove the five screws on the underside of the device using a PH0 screwdriver.
Step 6  ¶
  • Remove the five screws on the underside of the device using a PH0 screwdriver.
Step 7  ¶
Extend the solar panel into the upright position to access the screws on the backside of the device.
Step 7  ¶
  • Extend the solar panel into the upright position to access the screws on the backside of the device.
Step 8  ¶
Remove  the three screws at the top of the back panel using H2.5 hexagonal screwdriver.
Step 8  ¶
  • Remove the three screws at the top of the back panel using H2.5 hexagonal screwdriver.
Step 9  ¶
Remove the ten screws on the backside of the device using a long-neck PH0 screwdriver.
Step 9  ¶
  • Remove the ten screws on the backside of the device using a long-neck PH0 screwdriver.
  • Some of the screws are deep within the panel and require an appropriate (long neck PH0) screwdriver to access them.
Step 10  ¶
At this point, the back panel of the device should lift off easily. Lift it off and set aside.
Step 10  ¶
  • At this point, the back panel of the device should lift off easily. Lift it off and set aside.
Step 11  ¶
Use compressed air to clear away any dust or debris.
Step 11  ¶
  • Use compressed air to clear away any dust or debris.
Step 12  ¶
Inspect wires and locate any speaker loose connections.
Step 12  ¶
  • Inspect wires and locate any speaker loose connections.
Step 13  ¶
Solder loose wires back into place.
Step 13  ¶
  • Solder loose wires back into place.
  • Use the methods outlined in the ifixit soldering guide (link in the introduction).
