Help
Cambridge SoundWorks OontZ Angle Plus Battery Replacement
Replace the dead or dying in battery your Cambridge SoundWorks OontZ Angle Plus.
Use this guide to replace the battery.
Step 1 Battery  ¶
Unscrew the five 11.5mm Phillips screws on the bottom plate.
Step 1 Battery  ¶
  • Unscrew the five 11.5mm Phillips screws on the bottom plate.
Step 2  ¶
Carefully pull apart the bottom plate and the top plate, using the  blue plastic opening tool.
Step 2  ¶
  • Carefully pull apart the bottom plate and the top plate, using the blue plastic opening tool.
Step 3  ¶
Once the bottom plate and the top plate are separated, slowly pull the back plate away from the top plate.
Step 3  ¶
  • Once the bottom plate and the top plate are separated, slowly pull the back plate away from the top plate.
  • There are wires connected to both plates so do this step with care.
Step 4  ¶
Unscrew the two 10 mm Phillips screws on the brace  holding down the battery.
Step 4  ¶
  • Unscrew the two 10 mm Phillips screws on the brace holding down the battery.
  • Remove the brace that holds the battery in place.
Step 5  ¶
Separate the battery from the bottom plate and set the bottom plate aside.
Step 5  ¶
  • Separate the battery from the bottom plate and set the bottom plate aside.
Step 6  ¶
With some force, push the motherboard straight in toward the center of the device.
Step 6  ¶
  • With some force, push the motherboard straight in toward the center of the device.
Step 7  ¶
Pull the motherboard straight out of the device.
Step 7  ¶
  • Pull the motherboard straight out of the device.
  • There is some adhesive on the motherboard that holds it in place. This make the motherboard fit in the groove rather tight.
Step 8  ¶
Desolder the wires that connect the battery to the motherboard, negative (black wire) and positive (red wire).
Step 8  ¶
  • Desolder the wires that connect the battery to the motherboard, negative (black wire) and positive (red wire).
