Help
Logitech Harmony 650 Screen Replacement
How to replace the Screen on the Logitech Harmony 650 Universal Remote.
It is recommened that you have the iFixit ProTech toolkit and have already taken out the motherboard and taken apart the case.
Sections
Tools
Step 1 Screen  ¶
Remove the black rubber gasket that surrounds the screen from the top face of the motherboard. The gasket has 3 tabs along each side. The thick side of the gasket faces the top.
Step 1 Screen  ¶
  • Remove the black rubber gasket that surrounds the screen from the top face of the motherboard.
  • The gasket has 3 tabs along each side. The thick side of the gasket faces the top.
Step 2  ¶
Use a soldering iron to loosen the solder that connects the screen strip to the back of the motherboard. If it does not loosen easily then try using a soldering remover wick.
Step 2  ¶
  • Use a soldering iron to loosen the solder that connects the screen strip to the back of the motherboard. If it does not loosen easily then try using a soldering remover wick.
  • The soldering iron gets extremely hot use caution when using it around components.
Step 3  ¶
Use a metal spudger to cut the strip from the motherboard along the solder line.
Step 3  ¶
Step 4  ¶
Use a spudger or your hand to remove the screen from the motherboard. It is glued down.
Step 4  ¶
  • Use a spudger or your hand to remove the screen from the motherboard. It is glued down.
