Help
Motorola V400 Camera Replacement
Bullets!
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Missing Details
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
This guide details how to remove and replace the camera on the Motorola V400. It should take 5-10 minutes to complete.
To complete this guide you will need a pair of tweezers, a Torx T-6 screw driver, and a wedge to pry with. Before you start be sure to turn off the phone, remove the battery, and find a clean, water free work space.
Step 1 Camera  ¶
First, gather your tools. Tweezers T6 Torx driver
Step 1 Camera  ¶
  • First, gather your tools.
  • Tweezers
  • T6 Torx driver
  • Plastic opening tool
Step 2  ¶
Take out the battery first!!! Remove the four rubber stoppers around the main screen with tweezers. Remove the four rubber stoppers around the main screen with tweezers.
Step 2  ¶
  • Take out the battery first!!!
  • Remove the four rubber stoppers around the main screen with tweezers.
Step 3  ¶
Use a Torx T-6 Screwdriver to unscrew the 4 screws around the screen. Note that the top screws are black the the bottom screws are silver and that they are different lengths. Note that the top screws are black the the bottom screws are silver and that they are different lengths.
Step 3  ¶
  • Use a Torx T-6 Screwdriver to unscrew the 4 screws around the screen.
  • Note that the top screws are black the the bottom screws are silver and that they are different lengths.
Step 4  ¶
Use a plastic opening tool to separate outer shell from metal interior cover by sliding it along the crease in the case. To easily take off the case close the phone before trying to remove it. To easily take off the case close the phone before trying to remove it.
Step 4  ¶
  • Use a plastic opening tool to separate outer shell from metal interior cover by sliding it along the crease in the case.
  • To easily take off the case close the phone before trying to remove it.
Step 5  ¶
Use a plastic opening tool to separate the inner metal cover from the circuit board. Apply pressure to remove the piece. Use a plastic opening tool to separate the inner metal cover from the circuit board. Apply pressure to remove the piece. Use a plastic opening tool to separate the inner metal cover from the circuit board. Apply pressure to remove the piece.
Step 5  ¶
  • Use a plastic opening tool to separate the inner metal cover from the circuit board. Apply pressure to remove the piece.
Step 6  ¶
Remove rubber covering over the camera. Carefully remove camera and the attached orange ribbon by gently pulling on it. Pull out in the direction of the blue arrow. You can use your fingers or tweezers. Carefully remove camera and the attached orange ribbon by gently pulling on it. Pull out in the direction of the blue arrow. You can use your fingers or tweezers.
Step 6  ¶
  • Remove rubber covering over the camera.
  • Carefully remove camera and the attached orange ribbon by gently pulling on it. Pull out in the direction of the blue arrow. You can use your fingers or tweezers.
