Help
Samsung Eternity Motherboard Replacement
Bullets!
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
This guide will show you step-by-step instructions on how to remove the motherboard from the phone to replace it with a new one.
  • Author: Kevin Huang
  • Time estimate: 15 - 25 minutes
  • Difficulty: Moderate
You will need to find a clean area to work in and have the necessary tools. Follow this guide to gain access to your cellphone's motherboard.
Step 1 Motherboard  ¶
It is very easy to rip motherboard cables and damage fragile motherboard clips. Be careful when you are removing every component.
  • It is very easy to rip motherboard cables and damage fragile motherboard clips. Be careful when you are removing every component.
  • Pull the antenna plug out of its socket.
Step 2  ¶
Pop the two black hinged-release levers toward their ribbons, then slide the ribbons out. Pop the two black hinged-release levers toward their ribbons, then slide the ribbons out. Pop the two black hinged-release levers toward their ribbons, then slide the ribbons out.
Step 2  ¶
  • Pop the two black hinged-release levers toward their ribbons, then slide the ribbons out.
Step 3  ¶
Pop the red hinged-release lever away from its ribbon. Then pull it out.
Step 3  ¶
  • Pop the red hinged-release lever away from its ribbon. Then pull it out.
Step 4  ¶
Peel the button sensor on the side of the motherboard off of the case.
Step 4  ¶
  • Peel the button sensor on the side of the motherboard off of the case.
Step 5  ¶
Slightly pull up one side of the motherboard. Pull the button/microphone plug out of its socket. Pop the red hinged-release lever away from its ribbon, then slide the ribbon out.
Step 5  ¶
  • Slightly pull up one side of the motherboard.
  • Pull the button/microphone plug out of its socket.
  • Pop the red hinged-release lever away from its ribbon, then slide the ribbon out.
Step 6  ¶
You have successfully removed the motherboard from the phone.
Step 6  ¶
  • You have successfully removed the motherboard from the phone.
