Help
Dell Inspiron 8600 Top Case Replacement
Action Shots
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Incorrect Tools
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Markup Mishap
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Follow this guide to replace the top case of the Dell Inspiron 8600.
  • Author: Perry
  • Time estimate: 15 - 30 minutes
  • Difficulty: Moderate
Step 1 Top Case  ¶
First, remove all tabs using a flat head/ finger. Next, remove all screws using a #1 Philips screwdriver. Pull apart top case from the lower case. It will be quite difficult to separate.
Step 1 Top Case  ¶
  • First, remove all tabs using a flat head/ finger.
  • Next, remove all screws using a #1 Philips screwdriver.
  • Pull apart top case from the lower case. It will be quite difficult to separate.
Step 2  ¶
Remove all screws on the top of the lcd There all several screw on each side of the LCD. Remove all. There all several screw on each side of the LCD. Remove all.
Step 2  ¶
  • Remove all screws on the top of the lcd
  • There all several screw on each side of the LCD. Remove all.
Step 3  ¶
LCD should remove smoothly.
Step 3  ¶
  • LCD should remove smoothly.
  • The top case will be what remains.
