Help
Dell Latitude CS RAM Replacement
Member-Contributed Guide
This guide shows one how to remove the RAM on a Latitude CS.
  • Author: Axuak
  • Time estimate: 2 - 10 minutes
  • Difficulty: Easy
Not much prior knowledge is required before starting. According to Dell, however, you must have the following tools:
"‡#0 and #1 magnetized Phillips-head screwdrivers
‡ Small flat-blade screwdriver
‡ 5-mm socket wrench
‡ 7-mm socket wrench
‡ Small plastic scribe"
(Guide found at: http://tim.id.au/laptops/dell/latitude%2...)
Step 1 RAM  ¶
Flip laptop over. Flip laptop over.
Step 1 RAM  ¶
  • Flip laptop over.
Step 2  ¶
Remove the screws over the RAM door Remove the screws over the RAM door
Step 2  ¶
  • Remove the screws over the RAM door
Step 3  ¶
Open the RAM door. Open the RAM door.
Step 3  ¶
  • Open the RAM door.
Step 4  ¶
Carefully pull the tabs over the RAM chip down - the RAM will spring up. Carefully pull the tabs over the RAM chip down - the RAM will spring up.
Step 4  ¶
  • Carefully pull the tabs over the RAM chip down - the RAM will spring up.
Step 5  ¶
Remove the RAM from the socket and insert replacement RAM.
Step 5  ¶
  • Remove the RAM from the socket and insert replacement RAM.
