Help
HP Pavilion dv6700 Display/Monitor Replacement
Inconsistent Images
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Bullets!
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
This will show you how to replace the top half of the HP Pavilion dv6700.
  • Author: Alec Gramm
  • Time estimate: 10 - 20 minutes
  • Difficulty: Moderate
This guide would be used if your screen gets damaged or no longer functions. All screws are a PH00 size. It would be advisable to keep track of which screws go where, as there are a lot of screws that will be removed over the course of this guide. Be sure to wear the anti-static guard strap, as that will protect the circuitry from permanent damage from static electricity.
Step 1 Display/Monitor  ¶
Remove the RAM port cover. Screws will not fully remove. Loosen them until they turn freely.
  • Remove the RAM port cover.
  • Screws will not fully remove. Loosen them until they turn freely.
Step 2  ¶
Remove Hard Disk Drive (HDD) cover. Screws will not fully remove. Loosen them until they turn freely.
Step 2  ¶
  • Remove Hard Disk Drive (HDD) cover.
Step 3  ¶
Remove screws from the bottom. Remove screws from the bottom. Remove screws from the bottom.
Step 3  ¶
  • Remove screws from the bottom.
Step 4  ¶
Detach WiFi antenna wires. Be sure that the wires are labeled so you remember which ones go where. Be sure that the wires are labeled so you remember which ones go where.
Step 4  ¶
  • Detach WiFi antenna wires.
  • Be sure that the wires are labeled so you remember which ones go where.
Step 5  ¶
Remove two screws. Use a needle-nose pliers to do the initial loosening, then switch to using a hex screwdriver (size 5) head to do the rest of the loosening. Use a needle-nose pliers to do the initial loosening, then switch to using a hex screwdriver (size 5) head to do the rest of the loosening.
Step 5  ¶
  • Remove two screws.
  • Use a needle-nose pliers to do the initial loosening, then switch to using a hex screwdriver (size 5) head to do the rest of the loosening.
Step 6  ¶
Flip over HP Pavilion dv6700. Open up HP Pavilion dv6700.
Step 6  ¶
  • Flip over HP Pavilion dv6700.
  • Open up HP Pavilion dv6700.
Step 7  ¶
Use plastic opening tool to pry open the plastic bar above the keyboard. Be careful not to yank so hard that you rip out the ribbon cables underneath. There is enough room to pull safely, but use control to prevent damage. Be careful not to yank so hard that you rip out the ribbon cables underneath. There is enough room to pull safely, but use control to prevent damage.
Step 7  ¶
  • Use plastic opening tool to pry open the plastic bar above the keyboard.
  • Be careful not to yank so hard that you rip out the ribbon cables underneath. There is enough room to pull safely, but use control to prevent damage.
Step 8  ¶
Pull out and up on keyboard to remove it. Do not yank it all of the way out, as there is a ribbon cable underneath. Slide the two black locks on the side of the keyboard cable connection port up to release the cable.
Step 8  ¶
  • Pull out and up on keyboard to remove it.
  • Do not yank it all of the way out, as there is a ribbon cable underneath.
  • Slide the two black locks on the side of the keyboard cable connection port up to release the cable.
  • Grip the ribbon cable near the connection point and gently but firmly pull it out.
Step 9  ¶
Flip over the plastic bar. Detach the display connector.
Step 9  ¶
  • Flip over the plastic bar.
  • Detach the display connector.
  • Do not pull on the wires. Pull on the black plastic part or wedge a plastic opener or fingernail between the port and the connector.
Step 10  ¶
Detach the ribbon cables. Pull from the area closest to the connection port gently but firmly. Pull from the area closest to the connection port gently but firmly.
Step 10  ¶
  • Detach the ribbon cables.
  • Pull from the area closest to the connection port gently but firmly.
Step 11  ¶
Pull up on tape holding down wires. Pull up on tape holding down wires. Pull up on tape holding down wires.
Step 11  ¶
  • Pull up on tape holding down wires.
Step 12  ¶
Pull up on the WiFi wires and out from under the metal tabs. Do not yank them out. Let them hang loose once they are out from under the tabs. Do not yank them out. Let them hang loose once they are out from under the tabs.
Step 12  ¶
  • Pull up on the WiFi wires and out from under the metal tabs.
  • Do not yank them out. Let them hang loose once they are out from under the tabs.
Step 13  ¶
Disconnect the connector from the port. Remove the wire from under the metal tabs. Let wire hang loose after removing under the tabs.
Step 13  ¶
  • Disconnect the connector from the port.
  • Remove the wire from under the metal tabs.
  • Let wire hang loose after removing under the tabs.
Step 14  ¶
Remove the black screw in the top right corner. Remove the black screw in the top right corner.
Step 14  ¶
  • Remove the black screw in the top right corner.
Step 15  ¶
Pull upward on the screen connector tab. It will be firmly secured, so don't be afraid to use a little extra force to pull it off.
Step 15  ¶
  • Pull upward on the screen connector tab.
  • It will be firmly secured, so don't be afraid to use a little extra force to pull it off.
Step 16  ¶
Remove the black screw from the top left corner. Keep your hand on the screen to secure it, as once you remove this screw, it will come loose.
Step 16  ¶
  • Remove the black screw from the top left corner.
  • Keep your hand on the screen to secure it, as once you remove this screw, it will come loose.
  • Lift the screen off and set it aside.
