Help
Dell Vostro 1320 Screen Replacement
Incorrect Tools
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Markup Mishap
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Needs More Images
Needs More Images
A few more images would make this guide's procedures crystal clear.
Slice and Dice
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Better Introduction
Better Introduction
Improve this guide by completing or revising its introduction.
Replace the screen if it is no longer responding.
Step 1 Screen  ¶
Take screw covers off with a metal spudger
Step 1 Screen  ¶
  • Take screw covers off with a metal spudger
Step 2  ¶
Take the six screws out with the bit driver.
Step 2  ¶
  • Take the six screws out with the bit driver.
Step 3  ¶
Pop the black plastic panel off with the metal spudger. There are three spots where you should leverage it so that the panel does not break. Pop the black plastic panel off with the metal spudger. There are three spots where you should leverage it so that the panel does not break.
Step 3  ¶
  • Pop the black plastic panel off with the metal spudger. There are three spots where you should leverage it so that the panel does not break.
Step 4  ¶
Remove the plug on the bottom of the screen.
Step 4  ¶
  • Remove the plug on the bottom of the screen.
Step 5  ¶
Remove the two screws on the bottom of the computer screen.
Step 5  ¶
  • Remove the two screws on the bottom of the computer screen.
Step 6  ¶
Remove the tape and the LCD plug/connector from the back of the screen.
Step 6  ¶
  • Remove the tape and the LCD plug/connector from the back of the screen.
Step 7  ¶
Remove the three screws on the left and right of the screen. Remove the three screws on the left and right of the screen.
Step 7  ¶
  • Remove the three screws on the left and right of the screen.
Step 8  ¶
Remove the screen from the metal side frames.
Step 8  ¶
  • Remove the screen from the metal side frames.
