Help
Disassembling Sony Walkman NWZ-E438
Prerequisite Only
Prerequisite Only
Please note that this guide is only a prerequisite for other guides.
Opening the back panel of the Sony Walkman, you can gain access to the inside.
The Walkman uses a screwdriver to open the back of the device.
Step 1 Disassembling Sony Walkman NWZ-E438  ¶
Unscrew the two screws on the back of the device using a Phillips PH000 screwdriver.
  • Unscrew the two screws on the back of the device using a Phillips PH000 screwdriver.
  • Keep the Phillips PH000 screwdriver aside for further steps in the guide. It will be the only screwdriver needed for this replacement.
Step 2  ¶
Use a small prying tool to carefully pry open the back of the device.
Step 2  ¶
  • Use a small prying tool to carefully pry open the back of the device.
