Help
VTech Safe and Sound DM111-2 Plastic Clip Replacement
Replace the plastic clip on your device if it is damaged or broken.
  • Author: Melany Colon
  • Time estimate: 2 minutes
  • Difficulty: Easy
Use this guide if the plastic clip on your device is damaged or broken. Use caution when taking apart the device to avoid damaging internals and wires.
Step 1 Plastic Clip  ¶
Use the Philips #00 Screwdriver to remove the two 4 mm screws located on either side of the battery slots.
  • Use the Philips #00 Screwdriver to remove the two 4 mm screws located on either side of the battery slots.
Step 2  ¶
The white front covering of the device is held to the yellow back covering by four clips on the back covering which fit into tabs on the front covering. When separating the front and back cover, be careful not to separate the red and black wires which connect the batteries to the motherboard. Do not forcefully pull the two coverings apart.
Step 2  ¶
  • The white front covering of the device is held to the yellow back covering by four clips on the back covering which fit into tabs on the front covering.
  • When separating the front and back cover, be careful not to separate the red and black wires which connect the batteries to the motherboard. Do not forcefully pull the two coverings apart.
  • Insert the plastic opening tool into the seam between the front and back coverings to create a gap. The tools edge should point toward the front covering. It is easiest to start from the bottom of the device and slide the tool around the seam until all clips have been separated from the tabs.
Step 3  ¶
Use the Philips #00 Screwdriver to remove the 9.2 mm screw located in the middle of the back cover, above the battery compartment.
Step 3  ¶
  • Use the Philips #00 Screwdriver to remove the 9.2 mm screw located in the middle of the back cover, above the battery compartment.
