Help
MacBook Pro 13" Unibody Early 2011 Hard Drive Replacement
Replace the hard drive in your Early 2011 MacBook Pro 13" Unibody.
  • Author: Andrew Bookholt
  • Time estimate: 30 - 45 minutes
  • Difficulty: Moderate
Use this guide to replace a dead hard drive.
Relevant Parts (continued)
Step 1 Hard Drive  ¶
Remove the four 6.0 mm T6 Torx hard drive retaining posts from the sides of the hard drive. Transfer the hard drive retaining posts to your new hard drive.
Step 1 Hard Drive  ¶
  • Remove the four 6.0 mm T6 Torx hard drive retaining posts from the sides of the hard drive.
  • Transfer the hard drive retaining posts to your new hard drive.
  • If desired, transfer the pull tab over to your new hard drive.
  • If you are installing a new hard drive, we have an OS X install guide to get you up and running.
  • If you upgraded your EFI Firmware ROM you can also perform an internet recovery.
