Help
Sony Playstation 2 SCPH-79002 - Fan Replacement
Member-Contributed Guide
This guide will teach you how to replace the fan of the Sony Playstation 2.
  • Author: Zach luc
  • Time estimate: 5 - 10 minutes
  • Difficulty: Moderate
Step 1 Beginning  ¶
Flip your machine over
Step 1 Beginning  ¶
  • Flip your machine over
Step 2 Tabs  ¶
Grab a spudger and take off the tabs, like so.
Step 2 Tabs  ¶
  • Grab a spudger and take off the tabs, like so.
Step 3 Warranty Sticker  ¶
There is a warranty sticker that hides a tab, peeling it off will VOID your warranty!
  • There is a warranty sticker that hides a tab, peeling it off will VOID your warranty!
Step 4 Screws  ¶
Unscrew the screws
Step 4 Screws  ¶
  • Unscrew the screws
Step 5 Take off the back  ¶
Once you've done that, take off the back of the console. Once you've done that, take off the back of the console.
  • Once you've done that, take off the back of the console.
Step 6 Take off the fan  ¶
There are 3 screws that you need to unscrew, then you need to get a pair of tweezers and use a strong pull up. There are 3 screws that you need to unscrew, then you need to get a pair of tweezers and use a strong pull up.
  • There are 3 screws that you need to unscrew, then you need to get a pair of tweezers and use a strong pull up.
