Help
MacBook Pro 13" Unibody Early 2011 Battery Connection Replacement
Prerequisite Only
Prerequisite Only
Please note that this guide is only a prerequisite for other guides.
Disconnecting battery. Internal Prereq.
Disconnecting Battery. Internal Prereq.
Tools
Step 1 Battery Connection  ¶
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board. It is useful to pry upward on both short sides of the connector to "walk" it out of its socket. Be careful with the corners of the connectors, they can be easily broken off.
  • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
  • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket. Be careful with the corners of the connectors, they can be easily broken off.
Step 2  ¶
Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
Step 2  ¶
  • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
