Help
Kurio Xtreme Back Panel Replacement
Replace the broken back panel on your Kurio Xtreme.
  • Author: Mallory Myers
  • Time estimate: 5 minutes
  • Difficulty: Easy
If the back panel on your Kurio Xtreme is broken, it may not sufficiently protect internal parts and wires. Follow this easy guide to remove the broken back panel so that you can replace it with a new one.
Step 1 Back Panel  ¶
Remove the rubber case by beginning to peel from one of the top corners and continue peeling until the cover is completely removed.
Step 1 Back Panel  ¶
  • Remove the rubber case by beginning to peel from one of the top corners and continue peeling until the cover is completely removed.
Step 2  ¶
Unscrew the four 4 mm black screws using a Phillips #000 screw driver. There are two screws on each side of the device (four total).
Step 2  ¶
  • Unscrew the four 4 mm black screws using a Phillips #000 screw driver.
  • There are two screws on each side of the device (four total).
Step 3  ¶
Insert the plastic opening tool in between the edges of the blue front casing and black back casing. Slide the plastic opening tool around the perimeter of the device. This may require that you repeatedly run the opening tool up and down the edges of the device. Be sure not to break any of the plastic clamps along the edges of the device when removing the back cover.
Step 3  ¶
  • Insert the plastic opening tool in between the edges of the blue front casing and black back casing.
  • Slide the plastic opening tool around the perimeter of the device. This may require that you repeatedly run the opening tool up and down the edges of the device.
  • Be sure not to break any of the plastic clamps along the edges of the device when removing the back cover.
  • Carefully lift the back panel off of the rest of the device.
