Help
Insignia Flex 8 NS-15AT08 Back Casing Replacement
This guide shows you how to remove the back casing of the device.
Step 1 Back Casing  ¶
Insert a plastic opening tool into the seam between the back casing and the screen to separate the back casing from the tablet. You may need to use a metal opening tool for extra prying power, but beware that it can scratch your device or damage the internal components if the tool is inserted too deep.
  • Insert a plastic opening tool into the seam between the back casing and the screen to separate the back casing from the tablet.
  • You may need to use a metal opening tool for extra prying power, but beware that it can scratch your device or damage the internal components if the tool is inserted too deep.
  • You will hear the tabs pop as you separate the back casing around the tablet.
Step 2  ¶
Lift the back casing away from the rest of the device which should include the exposed circuit board and screen. Set the casing aside.
Step 2  ¶
  • Lift the back casing away from the rest of the device which should include the exposed circuit board and screen.
  • Set the casing aside.
