Help
iPhone 4 Verizon Volume Buttons Replacement
Replace the external metal volume buttons on your Verizon iPhone 4.
Use this guide to replace the metal volume buttons.
Step 1 Volume Buttons  ¶
Remove the three 1.6 mm Phillips screws securing the volume button bracket to the outer case.
  • Remove the three 1.6 mm Phillips screws securing the volume button bracket to the outer case.
Step 2  ¶
Pull the volume bracket slightly away from the outer case.
Step 2  ¶
  • Pull the volume bracket slightly away from the outer case.
  • Use a pair of tweezers to remove the volume buttons from the iPhone.
