Help
Palm Zire 31 Case Replacement
Taking off the case of the Zire 31.
  • Author: Antonio
  • Time estimate: 10 minutes
  • Difficulty: Easy
Step 1 Case  ¶
Unscrew the two 7.35mm Torx T6 screws.
Step 1 Case  ¶
  • Unscrew the two 7.35mm Torx T6 screws.
Step 2  ¶
Using the flat end of the spudger, carefully pry the black cover on the top from the blue front cover.
Step 2  ¶
  • Using the flat end of the spudger, carefully pry the black cover on the top from the blue front cover.
Step 3  ¶
Carefully remove the speaker from the back white cover by just pulling it gently. It is glued on.
Step 3  ¶
  • Carefully remove the speaker from the back white cover by just pulling it gently. It is glued on.
Step 4  ¶
Unscrew the #00 5.75mm Phillips screws from the bottom of the motherboard.  The front blue panel should fall right off.
Step 4  ¶
  • Unscrew the #00 5.75mm Phillips screws from the bottom of the motherboard. The front blue panel should fall right off.
