Help
Olympus FE-210 LCD Screen Replacement
Markup Mishap
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Featured Guide
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
This will guide you through the steps necessary for removing the LCD camera screen.
  • Author: Matt
  • Difficulty: Moderate
Before removing the LCD screen you must first remove the rear camera casing.
Sections
Step 1 LCD Screen  ¶
Remove the two 2.7 mm screws using a #00 screwdriver. After removing the screws the display will be free. Do not remove it. Like the rear case, there is a cord connecting it to the motherboard that must be disconnected first.
Step 1 LCD Screen  ¶
  • Remove the two 2.7 mm screws using a #00 screwdriver.
  • After removing the screws the display will be free. Do not remove it. Like the rear case, there is a cord connecting it to the motherboard that must be disconnected first.
Step 2  ¶
Using a spudger, lift the latch on the connector. Remove the ribbon cord from its connector. Remove the LCD from the rest of the camera.
Step 2  ¶
  • Using a spudger, lift the latch on the connector.
  • Remove the ribbon cord from its connector.
  • Remove the LCD from the rest of the camera.
