Help
Starbucks Barista Pump Replacement
This guide will teach you how to replace the Barista pump.
  • Author: Alex
  • Difficulty: Moderate
The pump is used to take the water from the reservoir to the portafilter and steam wand.
Step 1 Pump  ¶
Image 1/3: First remove all six screws on the back panel.
Step 1 Pump  ¶
  • First remove all six screws on the back panel.
  • Remove the back panel, then set it aside.
  • Remove the two screws holding the bottom panel in place.
  • Remove the bottom panel, then set it aside.
Step 2  ¶
Image 1/3: Pull the drip tray out, then set it aside.
Step 2  ¶
  • Pull the drip tray out, then set it aside.
  • Turn the brew unit clockwise to unscrew.
  • Pull the tube that goes into water reservoir out.
  • Slide the water reservoir out through the front of the barista to remove it.
  • Remove the top tray from the backside.
Step 3  ¶
Image 1/3: Use an adjustable wrench to unscrew the connection tube between the pump and the boiler.
Step 3  ¶
  • Use an adjustable wrench to unscrew the connection tube between the pump and the boiler.
  • Pull off both tubes connecting on each side of the pump.
  • Remove the 3 electrical connectors from the pump.
Step 4  ¶
Image 1/3: Unscrew the two mounting bolts.
Step 4  ¶
  • Unscrew the two mounting bolts.
  • Remove the pump unit from the Barista.
  • Pull off the yellow end of the pump and unscrew T-shaped end.
  • See the links section of the device page for where to purchase a new pump.
