Help
Palm TX Back Panel Replacement
How to remove the back panel of the Palm T|X.
  • Author: Spencer Lewson
  • Time estimate: 5 - 8 minutes
  • Difficulty: Moderate
Removing the back panel allows you to access the various parts of the Palm T|X PDA.
Step 1 Back Panel  ¶
Orient the device so that the display faces forward. Remove the stylus from the right side.
Step 1 Back Panel  ¶
  • Orient the device so that the display faces forward.
  • Remove the stylus from the right side.
Step 2  ¶
Turn over the device so that the back panel faces forward.
Step 2  ¶
  • Turn over the device so that the back panel faces forward.
  • Use a T5 Torx screwdriver to remove the four 6.35mm corner screws.
Step 3  ¶
Rotate the device so that the display faces forward. Insert a plastic opening tool with the angled tip pointing downward into the crevice on the left side of the device.
Step 3  ¶
  • Rotate the device so that the display faces forward.
  • Insert a plastic opening tool with the angled tip pointing downward into the crevice on the left side of the device.
  • Pry along the crevice to loosen the back panel.
  • Repeat this process for the right side.
Step 4  ¶
Carefully pry the back panel to open the device. Be careful not to break the wire that connects the battery pack to the motherboard.
Step 4  ¶
  • Carefully pry the back panel to open the device.
  • Be careful not to break the wire that connects the battery pack to the motherboard.
  • When reassembling, snap the back panel back into place and then insert the top cover.
Step 5  ¶
Use a plastic opening tool to peel the battery pack from the back panel. The battery pack is glued to the back panel so removing it may require considerable effort.
Step 5  ¶
  • Use a plastic opening tool to peel the battery pack from the back panel.
  • The battery pack is glued to the back panel so removing it may require considerable effort.
