Help
MacBook Core Duo Left Clutch Hinge Replacement
Replace a broken left clutch hinge in your MacBook Core Duo.
A MacBook display is only as good as its weakest link. If that weak link happens to be the left clutch hinge, replace it with a new one.
Step 1 Left Clutch Hinge  ¶
Remove the piece of tape stuck to the left clutch hinge.
  • Remove the piece of tape stuck to the left clutch hinge.
Step 2  ¶
Remove the single 3.2 mm Phillips screw securing the inverter cable to the left clutch hinge.
Step 2  ¶
  • Remove the single 3.2 mm Phillips screw securing the inverter cable to the left clutch hinge.
Step 3  ¶
Remove the three 3.2 mm Phillips screws securing the left clutch hinge to the rear display bezel.
Step 3  ¶
  • Remove the three 3.2 mm Phillips screws securing the left clutch hinge to the rear display bezel.
Step 4  ¶
Remove the left clutch hinge from the rear display bezel.
Step 4  ¶
  • Remove the left clutch hinge from the rear display bezel.
