Help
Disassembling Nokia 2366i Front Cover
This guide shows you how to remove the front cover of the Nokia 2366i.
  • Author: Kristen
  • Difficulty: Moderate
This guide shows you how to remove the front cover of the phone so that you can access the internal components found there.
Sections
Tools
Step 1 Front Cover  ¶
Keep the phone closed.
  • Keep the phone closed.
  • Hold the phones sideways with the front cover of the phone facing up.
Step 2  ¶
Find the slight crease on the side that divides the display assembly in half. Slowly wedge the spudger into the crease.
Step 2  ¶
  • Find the slight crease on the side that divides the display assembly in half.
  • Slowly wedge the spudger into the crease.
  • It's a little difficult to perform this step because the crease is narrow. Do not rush because you may damage the phone
Step 3  ¶
Run the spudger all along the crease while lifting up. Separate the front cover from the front base.
Step 3  ¶
  • Run the spudger all along the crease while lifting up.
  • Separate the front cover from the front base.
