Help
Garmin Nuvi 680 Motherboard Replacement
Inconsistent Images
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Confusing Text
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
A step-by-step guide to replacing the motherboard in the Garmin Nuvi 680.
Sections
Step 1 Motherboard  ¶
Use a PH1 sized Philips screwdriver to remove the two screws shown.
  • Use a PH1 sized Philips screwdriver to remove the two screws shown.
  • These screws are 6.88 mm long
Step 2  ¶
Carefully separate the motherboard from the outer case or the speaker and battery cables may be damaged. Use a spudger to lift the edge of the motherboard.
Step 2  ¶
  • Carefully separate the motherboard from the outer case or the speaker and battery cables may be damaged.
  • Use a spudger to lift the edge of the motherboard.
Step 3  ¶
Gently unplug the cable for the battery
Step 3  ¶
  • Gently unplug the cable for the battery
  • Gently unplug the cable for the speaker.
Step 4  ¶
Lift the motherboard out of the outer case.
Step 4  ¶
  • Lift the motherboard out of the outer case.
