Help
Technique: How to check Sony Ericsson W200i battery voltage
Guide to remove and check for battery problems in the Sony Ericsson W200i.
  • Author: Ryan Waltman
  • Time estimate: 5 - 10 minutes
  • Difficulty: Moderate
Checking the battery is fairly easy, all you will need is a multimeter, which can be purchased at a local hardware store.
Step 1 How to check Sony Ericsson W200i battery voltage  ¶
Plug the red probe into the center jack, the black probe into the bottom jack, and turn the range selector switch to 20 DCV. Turn the multimeter on.
  • Plug the red probe into the center jack, the black probe into the bottom jack, and turn the range selector switch to 20 DCV.
  • Turn the multimeter on.
Step 2  ¶
Touch the red probe to the indicated positive side and the black probe to the indicated negative side.
Step 2  ¶
  • Touch the red probe to the indicated positive side and the black probe to the indicated negative side.
  • Replace the battery if the voltage reads below 2.5 volts.
