Help
HP Mini 1000 LCD Assembly Replacement
Replace the LCD in your HP Mini 1000.
Step 1 LCD Assembly  ¶
If present, peel back the three pieces of cloth tape highlighted in red.
  • If present, peel back the three pieces of cloth tape highlighted in red.
  • If present, remove the small strip of black cloth tape highlighted in orange.
Step 2  ¶
Remove the nine 3 mm Phillips screws securing the LCD to the rear display bezel.
Step 2  ¶
  • Remove the nine 3 mm Phillips screws securing the LCD to the rear display bezel.
Step 3  ¶
Lift the lower right corner of the LCD enough to de-route the antenna cables from its frame.
Step 3  ¶
  • Lift the lower right corner of the LCD enough to de-route the antenna cables from its frame.
Step 4  ¶
Lift the left edge of the LCD out of the rear display bezel and de-route the cables from the brackets along the left side.
Step 4  ¶
  • Lift the left edge of the LCD out of the rear display bezel and de-route the cables from the brackets along the left side.
Step 5  ¶
Remove the LCD from the rear display bezel.
Step 5  ¶
  • Remove the LCD from the rear display bezel.
  • If your new LCD has no brackets included, swap the brackets from the old LCD to your new one.
