Help
HP Mini 1000 Hard Drive Replacement
Prerequisite Only
Prerequisite Only
Please note that this guide is only a prerequisite for other guides.
Internal Prerequisite.
Step 1 Hard Drive  ¶
Use your fingernail or the flat end of a spudger to flip up the retaining flap on the SIM card ribbon cable ZIF socket. Be sure you are prying up on the retaining flap, not the socket itself.
Step 1 Hard Drive  ¶
  • Use your fingernail or the flat end of a spudger to flip up the retaining flap on the SIM card ribbon cable ZIF socket.
  • Be sure you are prying up on the retaining flap, not the socket itself.
  • Pull the SIM card ribbon cable out of its socket and peel it off the top of the hard drive enclosure.
Step 2  ¶
Use your fingernail or the flat end of a spudger to flip up the retaining flap on the hard drive cable ZIF socket.
Step 2  ¶
  • Use your fingernail or the flat end of a spudger to flip up the retaining flap on the hard drive cable ZIF socket.
Step 3  ¶
Remove the two 4.5 mm Phillips screws securing the hard drive to the lower case.
Step 3  ¶
  • Remove the two 4.5 mm Phillips screws securing the hard drive to the lower case.
Step 4  ¶
Lift the hard drive up and out of the lower case, being careful not to damage its cable in the process. Lift the hard drive up and out of the lower case, being careful not to damage its cable in the process.
Step 4  ¶
  • Lift the hard drive up and out of the lower case, being careful not to damage its cable in the process.
