Help
HP Compaq 6710b Keyboard Replacement
Quick and easy steps to replace your keyboard!
  • Author: Khulan Orgil
  • Time estimate: 15 - 20 minutes
  • Difficulty: Moderate
Keyboard removal is necessary to replace heat sink paste and ram.
Step 1 Keyboard  ¶
Turn off computer before starting. Flip to the backside of the laptop. Using a Phillips #1 screwdriver, unscrew the 5mm screw and take off the shown cover.
Step 1 Keyboard  ¶
  • Turn off computer before starting.
  • Flip to the backside of the laptop.
  • Using a Phillips #1 screwdriver, unscrew the 5mm screw and take off the shown cover.
  • Using the same screwdriver, unscrew the 8mm screws.
  • The screws may not completely fall out of the laptop, just ensure they are unscrewed as far as they will go.
Step 2  ¶
Flip over the laptop to the top side, and open the laptop.
Step 2  ¶
  • Flip over the laptop to the top side, and open the laptop.
  • Slide the locking tabs down using a blue plastic opening tool or your fingernail.
Step 3  ¶
Using the plastic prying tool, lift the keyboard gently towards you. Don't take the keyboard completely off because it is still attached with a ribbon cable to the computer.
Step 3  ¶
  • Using the plastic prying tool, lift the keyboard gently towards you.
  • Don't take the keyboard completely off because it is still attached with a ribbon cable to the computer.
Step 4  ¶
Pull up on both sides of the black locking tab of the connector.
Step 4  ¶
  • Pull up on both sides of the black locking tab of the connector.
  • The keyboard should now be free of the computer.
