Help
Trio Stealth Pro 9.7" Volume Button Replacement
Bullets!
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Better Introduction
Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
A step-by-step guide on how to replace a Trio Stealth Pro 9.7" volume button.
Step 1 Volume Button  ¶
Remove 2 black 4 cm Phillips screws on either side of the bottom of the device.
  • Remove 2 black 4 cm Phillips screws on either side of the bottom of the device.
Step 2  ¶
Use the plastic opening tools and the spudger around the outside of silver metal back plate on the device to pry off the back plate. Use the plastic opening tools and the spudger around the outside of silver metal back plate on the device to pry off the back plate.
Step 2  ¶
  • Use the plastic opening tools and the spudger around the outside of silver metal back plate on the device to pry off the back plate.
Step 3  ¶
Remove 2 silver 4 cm Phillips screws in the top right side of the device.
Step 3  ¶
  • Remove 2 silver 4 cm Phillips screws in the top right side of the device.
Step 4  ¶
Cut 4 wire flex cable connecting the motherboard to the volume controls. Remove volume control buttons.
Step 4  ¶
  • Cut 4 wire flex cable connecting the motherboard to the volume controls.
  • Remove volume control buttons.
