Help
Dell Latitude E4200 SSD Replacement
This guide will go through the necessary steps in order to replace the SSD.
Follow these steps in order to successfully replace the SSD of your laptop.
Sections
Tools
Step 1 SSD  ¶
Unscrew the two 4.10x4.05 mm screws holding the SSD in place.
Step 1 SSD  ¶
  • Unscrew the two 4.10x4.05 mm screws holding the SSD in place.
Step 2  ¶
Using your finger and thumb lift the hard drive out of the computer but do not disconnect the attached connector to the computer.
Step 2  ¶
  • Using your finger and thumb lift the hard drive out of the computer but do not disconnect the attached connector to the computer.
Step 3  ¶
By applying pressure to the sides of the connector, pull the connector apart from the SSD.
Step 3  ¶
  • By applying pressure to the sides of the connector, pull the connector apart from the SSD.
